D16Z6 Into 96 EJ8 Using ODB2 Harness and P2P ECU - cranks but won't start
Hey everyone, so I just finished this swap in my coop, and it wont start, i think the immobilizer is coming on, as no relays are being activated at ignition.
What do I do here to get it started? I aint cranked it once yet.
Thanks in advance for any help.
Re: D16Z6 Into 96 EJ8 Using ODB2 Harness and P2P ECU
so, I got the immobilser thing figured out, it just needed another earth
but, now its cranking but will not start.
It is getting fuel and spark, but will not fire up, can anyone help? Its such an odd situation.
Re: D16Z6 Into 96 EJ8 Using ODB2 Harness and P2P ECU - cranks but won't start
Is spark bright white at the plugs?
Are the plug wires installed in the correct firing order on the distributor cap?
Are the fuel injectors spraying when the engine is cranked?
Is the mechanical timing set correctly?
Can someone operhaps direct me to a link for the correct firing order? I have tried a few but it still wont go.
Timing is set.
Checked the plugs for spark, there is spark, but I am about to get some new plugs tonight.
Have not checked the injectors are sparying, will do this tonight.
I really think the firing order is wrong, and I have searched, and tried a few differnc combinations, btu there is so much conflicting information.
Which order is correct?
Also, I presume that you'll need an OBDII-OBDI conversion harness and an OBDI ECU for your set up. For example, are several CEL codes thrown?
I am using the full d16Y8 intake setup, so odb2 loom and ecu.
only one code, 6, water temp sensor.
that waht i was looking for, thanks.
Thanks for the PM eric.
I just tied cranking it again tonight, but no joy.
checked
fuel, spark, both ok
changed
leads and new plugs.
tried,
advancing timing, cranking it lots and lots.
nothing has worked.
Eric suggested I need a crank sensor. How do I add this considering I have no wires left over in my harness?
checked
changed
tried,
nothing has worked.
Is the crank sensor for the D16Y8 inside the distributer? 5 take it the D16Z6 dizzy does not have one....???
Former Moderator
It absolutely should be throwing codes though.
EDIT
Use the OBD2A instructions.
ok, cool, will do this tomo, and get back to you all.
thanks for the help so far everyone.
Seagull Management
What country are you in? I'm guessing its not north america from seeing earth instead of ground and also due to the mention of the immobilizer, both suggest Europe to me. The reason I ask is because i'm not sure that European OBD2 civics had a CKF sensor, JDM models definately didn't.
I am in Scotland.
Yeah, the only code it is throwing is 6, which I understand to be water temp.
I really do not know if it has a CKF sensor. It is not throwing a code to indicate this,and also I do not recall having to unplug anything near the oil pump when I took the D16y8 out.
I am totaly out of ideas why It will not start when cranked.
try spraying carb or intake cleaner into the throttle body well cranking it over if it fire's you know the problem is with fuel. i have seen injectors seize if they set for awhile are you useing the z6 or y8 ?
So I have been reading that there are differnces in the timing between the z6 and y8.
So it is not going to run whatsoever unless i run a jumper harness and a p28 ecu.
Is this right?
Is it even possible to run a z6 on a p2p ecu????
Is this right?
hey canadaek., it is getting plenty of fuel, i took the old plugs out and they had pleanty of fuel on them, they were a bit wet with fuel.
I am starting to wonder if it is even possible to run a z6 on a p2p ecu.
Set the engine to TDC1 and take clear pictures of the cam and the crank (alignment of pointer with crank pulley marks).
Is there bright white spark at all four plugs?
What are the cylinder compressions?
Are the injectors spraying gas when the engine is cranked?
