d16z6 injectors on d15b7
i just did a quick search and came up with a little info but,
i just took the intake mani off my z6 and was wondering..
will it make a difference if i swap out my dx ( i believe 180cc) injectors for the z6 (240cc) injectors??
would i be running to rich or lean??
and i have a header on and i recall someone saying you can tell if your running rich/lean by the color of your header (blue/copper)..?
and if i do swap out my injectors will i need to swap out the rail as well as the wires that lead to the top of the injectors?? or can i just exchange the basic injector?
thanks for the help
thanks for the help
Re: d16z6 injectors on d15b7 (Cuong-nutz)
HA ...wheres that hammer hitting head icon..
but can you tell if your running rich or lean through the color of your header or was it just bs??
Re: d16z6 injectors on d15b7 (lemon_juice)
They are both 240cc injectors wont make a difference unless one has less miles on it then it might be cleaner. Also you wont be able to tell by the color of a header....lol reading your plugs is the easy way, best way is wideband o2
If you did a injector swap its all the same just change them out no need to change the plugs on the injectors or the fuel rail. Hope this answers all your questions
Re: d16z6 injectors on d15b7 (eg4usdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg4usdm »</TD></TR><TR><TD CLASS="quote">HA ...wheres that hammer hitting head icon..
but can you tell if your running rich or lean through the color of your header or was it just bs??</TD></TR></TABLE>
hammer on your head foo'. the injectors are not the same cause i have a d16z6 and the injectors have a part #4108 and the d15 is #4106. i had to swap mine and there are not the same it is d15 180 cc and d16z6 is 240cc. they will fit though but u might be running rich but its the other way around like me youll be running lean but i think ull be fine if u have other mods on your car like a cai. this will help it even it out. Running rich has also to with your ecu, o2, etc. there is a thread on this board where it show the cc for each injector but it only show ex/si 92-95 which is d16z6 but no smaller trim.
92ehatch
02-08-2007 04:47 AM
