d16z6 head gasket measurement
Old 06-12-2007, 07:38 PM
dragonfly2k3's Avatar
Default d16z6 head gasket measurement
Hey guys, im going to be buying a new head gasket, and i see all of these different measurements. as in 76 mm 77mm 78mm 79mm and 80mm. Are these actually measure .077mm and so on of thickness or is that a bore measurement?
Old 06-12-2007, 09:12 PM
Boosted4life's Avatar
Default Re: d16z6 head gasket measurement (dragonfly2k3)
its bore
Old 06-12-2007, 10:36 PM
dohcdelsol's Avatar
Default Re: d16z6 head gasket measurement (slow guy)
its the cylinder bore and the stock bore for the z6 is 75mm. best gasket to get is OEM.
Old 06-13-2007, 04:04 AM
Default Re: d16z6 head gasket measurement (dohcdelsol)
I would do that, but when i bought my car someone had built the bottom end and i am not sure how large over they bored it. I guess i could have to get a micrometer to measure. Is it ok to use a smaller bore head gasket than the cylinder bore?
Old 06-13-2007, 06:00 AM
SOHC IT's Avatar
You want the gasket to be larger than the bore by at least .5mm (.020"). OEM gasket thickness should be in the ballpark of .030" (.75mm)
racerguy
Engine Machining & Assembly
01-12-2019 09:38 PM
60019184
12-14-2014 04:21 PM
Eghatchgsr8
09-19-2014 02:24 PM
roycivic92
04-07-2010 10:07 AM
jt-sport
11
02-11-2004 02:57 PM
Quick Reply: d16z6 head gasket measurement
