D16Z6 Head On A D18Y8 Block...Which Camgear?
D16Z6 Head On A D16Y8 Block...Which Camgear?
Im a bit confused as to which camgear is should get from golden eagle...should I go with the z6 or y8 cam gear...also i will be using the z6 cam (same as y8 or should I swap them??) but i believe i need to advance the cam timing about 5*??
Modified by CivicMike at 5:16 PM 5/31/2006
Re: D16Z6 Head On A D16Y8 Block...Which Camgear? (CivicMike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicMike »</TD></TR><TR><TD CLASS="quote">D16Z6 Head On A D18Y8 Block...Which Camgear?
Im a bit confused as to which camgear is should get from golden eagle...should I go with the z6 or y8 cam gear...also i will be using the z6 cam (same as y8 or should I swap them??) but i believe i need to advance the cam timing about 5*??</TD></TR></TABLE>
I personally would run the Zex/Comp 59300 cam and Zex cam gear for the z6 head.
Skadaloz
06-02-2009 06:14 PM
B16aDasher
03-07-2005 04:19 PM
