d16z6 compression
d16z6 compression
what is the compression my cylinders should have on a d16z6 cuz i did a test it came out to 150-160 on every cylinder
It might help, also you should crank it over with all the plugs removed, crank the engine for between 3 to 5 revolutions, and if you have one I like to hook up a battery charger to keep the crank power up
sorry to thread jack. but wat is the proper way to check compression. i did mines today and i got 120 all cylinders. i did something wrong, or something is wrong?
Looks like you have a problem there. try putting about 2 tbl spoons of oil down each cylinder and retest the cylinder if compression comes up you have bad rings. if things don't change try doing a leak down test. If nothing happens with that you could also have a blown head gasket
xXx Justin xXx
05-15-2003 09:42 PM
