d16z6 bronze valve guides daily driven turbo??????
okay i just got my d16z6 head finished form the machine shop.
it was shaved and valves installed. new seals, and bronze valve guide. my machinist told me that he ordered the valve bronze valve guides. the head is shaved and i got it back. this will go on a d16z6 block w/vitara piston and h beam eagles. whats the benefit for the bronze valve guides? pros/cons using them... i need to know how long do these last. i will use it as a daily driver and na till i get my turbo setups... whats bad about the bronze valve guides did i make a mistake??? whats your guys opinnions on bronze valve guides experiences/and street how long last milages// pls let me know thankss |
Re: d16z6 bronze valve guides daily driven turbo??????
use OEM valve guides if this is going to be a daily they obviously go miles and miles on factory cars..... some people like to over think their build too much.... sometimes OEM>Aftermarket for longevity
suxs i already installd on the motor. how long will they last? i will go boost in a year.
anybody have experience with running bronze valve guides. with daily driven cars... |
What valves are you using? Bronze alloy valve guides will dissipate heat faster, but wear and longevity depends entirely on the relationship between the valves and valve guides. If you're using aftermarket, stainless valves, bronze valve guides are the correct pairing. If you're using stock valves, bronze guides can chew them up.
Originally Posted by jbpnoman
(Post 48878198)
im sure he ordered the correct bronze valve guides/ anyone experience these w/oem vavles? my machinist told me that the valve to guid will have better less friction and better and also expands when hot something like that. but i forgot it was long time ago. its my daily driver and how long do these last. what problems can these stupid bronze valve guides cause my engine. |
it will burn oil when the engine is cold warming up when the valve seals go or smoke during vtec... u will know when they go
Originally Posted by apexi_rsx
(Post 48878462)
you should get 20k miles out of it before u need to worry...
(Post 48878767)
what casuse my glittery oil pan? |
Knock + metal shavings in oil = spun bearing.
