d16y8 vs.d16z cam question,vehicle weight 2
I would like to know if the d16z aftermarket or oem cam,retainers and springs will fit in a d16y8 cylinder head.
what is the dry vehicle weight of an ek civic lx in comparison of a civic ex.
Re: d16y8 vs.d16z cam question,vehicle weight 2 (devine wind)
i think all the valvetraing and cam will work. check on a site that sells aftermarket cam for them and check the part# if they are the same for both you got a definate answer. you can also try searching this site. im sure its been asked before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devine wind »</TD></TR><TR><TD CLASS="quote">I would like to know if the d16z aftermarket or oem cam,retainers and springs will fit in a d16y8 cylinder head.
Yes and no, the cam timing will be off enough to drive you nuts unless you use a Z6 cam gear.
The LX is slightly lighter than the EX. Not enough to matter being the EX comes with a nicer transmission and engine.
http://www.crower.com makes cams/springs/retainers for the Y8 and the Z6.
Re: (devine wind)
If you go with the zex 59300/105300, then you have to get either the zex/comp valvetrain or the skunk2 valvetrain. They are the only ones that I have found that can handle the 0.455 lift on the zex cam.
mdrouillard1983
07-16-2014 04:39 PM
All_Lag
08-10-2003 06:47 AM
