D16y8 tranny problem...HELP
well i got a y8 in a eg and lately ive been noticing that its hard to get my shit in gear for somereason what could be makin this happen??? and when its hot it gets worse i think , i put oil in when we put the motor in 4 months ago so im asuming that cant be it....
Have you flushed your transmission and place new fluid in there? Usually, when you get a used engine/transmission, it's better if you place all new fluid in there, you don't know the condition of it.
Go to your local GM Dealer and pick up 2 quarts of GM Synchromesh Friction Modified. Run it for 500 miles and check if it's still hard to shift. What are the condition of your shifter bushings? |
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">
Go to your local GM Dealer and pick up 2 quarts of GM Synchromesh Friction Modified. Run it for 500 miles and check if it's still hard to shift. </TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif 10w30 can work, but if the tranny's been dry for a while, then it's good to use GMSMFM or at least Honda MTF. |
yea we did flush the tranny when we did the swap, but u see right after i did the swap maybe 2 days i drove out here to so cal from CO non stop and been drving alot out here and havent changed or checked it. My shifter bushings i was thinkin could be the problem , i checked at my work (autozone) if we had some and we dont https://honda-tech.com/forums/images/smilies/emsad.gif ... i will check out that GM fluid bro https://honda-tech.com/forums/images...es/emsmile.gif thanks
No problem.
how's your clutch doing?
should be good i hope , its my friends old one..he ran it for like 6 weeks , its a ACT 6 puck
Re: (sheepeg3)
is it hard to get into while the car is off?? or just when its running..... i had the same problem with my gsr tranny.. the clutch was shit.
Re: (sheepeg3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepeg3 »</TD></TR><TR><TD CLASS="quote">should be good i hope , its my friends old one..he ran it for like 6 weeks , its a ACT 6 puck </TD></TR></TABLE>
try bleeding it too... its easy and it may be keeping your clutch from fully disengaging |
ok i just went to check and ONLY when i drive....damn dude... i hope its not the clutch...and like i have noticed that lately my shit dont grab like it use to when i first got it in...
well thast also cuase i couldnt drive it with 6 puck and had to learn so maybe i just got use to it and drive it better i dunno :/
Re: (sheepeg3)
id just try bleeding out the clutch like 10 more times over and over, if it dosent change anything its probably your clutch, and would it happen to be a exedy by chance?... cause we just put one of them in my friends gsr and it sounds like the same problem its hard to get into gear especially first when you want to go lol
na its a ACT 6 puck.... but it just started doing this....but i will do that thanx guys much <3
