d16y8 swap with code 91
OK, I swapped a d16y8 into a 97 civic cx hb andl i was searching around and I heard that you can use a 96-97 del sol ecu and not get the code 91
since they DONT have the ftps. but they do have the same engine D16Y8
would that be the best thing to do by using a del sol ecu?!? instead of fooling the ecu or swapping the fuel tank?
let me know what you guys think thanks!
Re: d16y8 swap with code 91
i think they have tricks for this if you google search it. but i believe all civics 96-98 do not have this sensor. you could run these ecu's as well.
are you talking about this? http://ff-squad.com/technet/code91.htm
I would do the potentiometer trick but its unreliable... the cel will just come back on
if i were to get the del sol ecu what harness will i need to get for it?
Fabian@delsol
Engine Management and Tuning
10-10-2014 08:45 PM
