D16Y8 rough idle
D16Y8 rough idle
My check engine light came on and now sometimes at idle the cars rpms jump between .5k to 1.2k while its in drive (it automatic) but when i get done driving i put it in park it starts doing it right away. i also notice it does it when i'm moving with out having my foot on the gas petal. i have no idea what would be doing this, i checked the spark plug and wire and the air filter it is all clean. the car starts with no problem but after about 5min of idle it starts up while in park!
Any info please would help
Update 05/31/09 4:56pm
Just got the code P0505 Idle Control System Malfunction
So anyone got anything on this i can check?
update 06/01/09 11:16am
When i got the car this line was blocked off, and the hose was just laying there. so i thought it pluged into this port on the intake manifold. was i wrong? what is this port, i never saw this before?
Re: D16Y8 rough idle
you dont need to drive it anywhere https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/engine-swap-info-faqs-how-ck-engine-lights-878010/
Idle Control System Malfunction is what the code stands for so anyone got any ideas what i can do here? and when does that check engine light go out?
With the warm engine idling and the intake removed, cover the lower port leading to the IACV inside the throttle body with your finger.
1) If the idle speed does not drop, you have a vacuum or intake air leak.
2) If the idle speed does drop, try to adjust the idle speed with the idle screw on the throttle body. If the idle speed cannot be adjusted, replace the IACV.
I just looked at the service manual and here are the possible causes for P0505:
- IACV mechanical malfunction
- Throttle body clogged port, improper adjustment
- Intake manifold gasket leakage
- Intake air hose loose leakage
- Vacuum Leak
- ECT (Engine Coolant Temperature) sensor incorrect output
- Throttle Position sensor incorrect output
So you don't have to check for proper voltage on the IACV even though it won't hurt if you do.
- Vacuum Leak
all good INFO thanks so much i'll be hitting this up ASAP now will the check engine light go out or do i have to reset some, and where is that rest button?
to reset you could always just disconnect the battery eat some dinner hook it back up everything should be cleared might run rough at first though
The CEL will continue to illuminate until you fix the underlying cause of the problem, which is likely a bad IACV or an intake air/vacuum leak. When you have fixed the problem, then clear the ECU. This can be done by removing the 7.5A BACKUP fuse under the hood for a few minutes. If the problem is repaired, then the CEL will no longer be triggered by code P0505.
I had the same problem for the longest time and could not figure it out. I went through all the steps that everyone has already listed. It turns out that the throttle cable was too tight, and it was causing a small vacuum leak at idle. I loosened it up, reset the cel and everything's good now.
i think i'm missing something cause there is nothing else disconneted just that hose was laying there and the tube sticking out of the manifold was capped off. I hate this motor so much i miss my b series! all this OBD 2 **** is a pain
It seems like your FIA Control Valve was removed. You need to get a new one and run it the way it's shown in Ron's post. Right now you have plugged the hose coming from the intake straight to the injectors. What you need to do is insert the FIA Control Valve in between.
