d16y8 manual swap engine harness question. What auto plugs can I use?
Im using the harness from my 97 d16y7 AUTO. So I can use any of the Auto Tranny plugs. Can I use any of them for the knock sensor, vtec OP, or IACV? If I can it would save a lot of time looking for the plugs at junkyards.
Thanks
Thanks
after checking some of them out it seems as though none of them will work. I do know that the thermostat plug and coolant temp can be used for the Vtec OP. Now I just need to find one in a junkyard, soo the question is now is there nay difference between the 92-95 plugs and the 96-00 plugs?
Re: (pumpkyn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pumpkyn »</TD></TR><TR><TD CLASS="quote">soo the question is now is there nay difference between the 92-95 plugs and the 96-00 plugs?</TD></TR></TABLE>
Re: (pumpkyn)
some are different, some are the same, 2 pin IACV plug is the same, 2 pin oil temp, collent temp, things like that are the same, distributer plug is different, injector plugs are different etc..
Re: (Kovatch EG)
found a 92 and that was stripped to **** but i found the VTEC OP and 2-wire IAVC. Now i just need the knock sensor which is single so i may just make my own connection. Unless anyone knows where i could find one of those
