d16y8 into a 95 dx
d16y8 into a 95 dx
can this be done ? i got a free complete motor, except it was from an automatic and still has the torque conveter . can i just replace it with a flywheel and will it bolt right up to tranny? can i use an ecu for that motor except make sure its for a manual tranny? HELP!!! I really want this motor in my car, my d15 is slow. any links on DIY ?
Re: d16y8 into a 95 dx (BUG_MANIAC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUG_MANIAC »</TD></TR><TR><TD CLASS="quote">can this be done ? i got a free complete motor, except it was from an automatic and still has the torque conveter . can i just replace it with a flywheel and will it bolt right up to tranny? </TD></TR></TABLE>
That is what I did when I blew out my first Y8.
What tranny are you going to use?
Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool »</TD></TR><TR><TD CLASS="quote">I'm doing that now with my built Y8, it's from an auto Y8 car.
Side note, are the cams the same in the Auto vs 5 speed D16Y8?</TD></TR></TABLE>
LoL you ask after you build it
Yes, the cam is the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUG_MANIAC »</TD></TR><TR><TD CLASS="quote">where can i get this harness. how do i wire vtec and knock ? a least i know it can be done!</TD></TR></TABLE>
Kenji on this board makes harnesses.
i did a d16y8 into my 92 vx. had the same thing an automatic d16y8, had to change the intake manifold because the automatics have different idle control valve then what is neede on 92-95. otherwise yes u can just bolt up the flywheel. also there is a brace on bottom of engine to trans, they are different on auto/manual, at least mine was. i used my vx wire harness and had to wire up the injector harnesses from the y8. another thing the ditributor on my vx did not bolt up to the y8, what i did is took everything out of the vx distributor and put it in the y8 case. i was lucky with the vtec already hooked up, so didnt do that. but had to convert my 5 wire o2 to 4 wire, which i just ran directly to the p28 ecu. the setup works fine for me so far.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUG_MANIAC »</TD></TR><TR><TD CLASS="quote">how can i come in contact with kenji?</TD></TR></TABLE>
He's on this board under the name Kenji. PM him.
92d15b7
15
01-02-2014 09:16 AM
ccjustin
03-23-2006 02:36 PM
