D16Y8
D16Y8
Can you guy's help me make a list of possible performance upgrades someone can do on a D16Y8
this is wut i came up with
Intake system
throttle body
intake manifold
fuel rail
fuel pressure regulator
fuel filter
fuel pump
fuel injectors
head work
pistons
rods
crank
cam
cam gear
pulley kit
exhaust manifold
high flow cat
cat-back exhaust
header
turbo
intercooler
lowering springs
coilover kit
drag kit
clutch
flywheel
short shifter
thats pretty much all i can think of anyone else care to chip in and help let everyone know wut the performance parts are that you can upgrade a D16Y8
everyone says how shitty it is and stuff well i think b16 and b18's are over used and even h22 or b20 way too over used i want to see a d16 sit on top of all the boards and here is where you can help me accomplish that
ppl can look at this and start upgrading there d16 and kill all those d and h series
Intake system
throttle body
intake manifold
fuel rail
fuel filter
fuel pump
fuel injectors
head work
pistons
rods
crank
cam
cam gear
pulley kit
exhaust manifold
high flow cat
cat-back exhaust
header
turbo
intercooler
lowering springs
coilover kit
drag kit
clutch
flywheel
short shifter
Re: D16Y8 (96CivicBoostCoupe)
https://honda-tech.com/zerothread?id=261161
That might help you out.
Edit: wait no... this one is better https://honda-tech.com/zerothread?id=335078
Re: D16Y8 (Paul99EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96CivicBoostCoupe »</TD></TR><TR><TD CLASS="quote">That about covers it with the exception of DOHC</TD></TR></TABLE>
^^dont listen to him . the SOHC is where its at ^^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul99EX »</TD></TR><TR><TD CLASS="quote">I say maybe an OBD1 conversion with some kind of EMS, such as uberdata, hondata ect.... Just my 2 cents</TD></TR></TABLE>
Totaly aggree.. maybe look in to chrome also. or the new Hondata s300 is coming out here in Aug.
Re: D16Y8 (JDMKid71)
I would wait until you decide if youre going to be boosting or not. Then look into what EMS set up would be best for you. If you want, you can just run an AFC unitl you boost, but there probably isnt much need to.
OBD1 conversion???
wut the hell is that??
i've seen it all over
but i dont know wut
the hell it is!
OBD1 conversion???
but i dont know wut
the hell it is!
Re: D16Y8 (97exd16)
haha simmer down there...
Your car is running an OBD2 computer, which is shitty ( i know i have OBD2), OBD2 is made moe for EPA and emissions. With obd1, you can chip the ecu with programs such as uberdata, chrome, hondata, ect.... Basically giving you more options and it also knocks out the cat o2 sensor. Research is a little bit too. But for an OBD1 conversion, you would need an OBD2A (i believe) to obd1 conversion harness, an obd1 ecu (pref p28) and possibly an obd1 dizzy.
save some money and work with what you have.. port and polish your head, bore out your throttle body, get hondata so u dont have to get fuel items and tune those by yourself. if your not boosting or nitrous just keep your crank and get it micro polished and balanced. can't go wrong with some forged pistons and rods. yeah get a nice clutch set up. through some nitrous and a cam on there and you'll be good to go with a tune
