d16y7 question
d16y7 question
i am having a problem figuring out a plug thats on my y7
it comes out of the timing belt side, right above the oil pan
any ideas what it is??
i dont have a pic right now i will have one later if it helps
TIA
TIA
Re: d16y7 question (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">An OBD0 ECU will not look for it</TD></TR></TABLE>
ok lemme explain what im doing
i have a 88 crx hf and i got this y7. i am puting all crx si parts on it to make it obd0 like the intake mani,header,dizzy,ecu,trans
so i dont need the crank sensor right?
thanks
thanks
Re: d16y7 question (Wilson_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wilson_ »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wilson_ »</TD></TR><TR><TD CLASS="quote">so i dont need the crank sensor right?
thanks</TD></TR></TABLE>
Correct, you dont need it!
Re: d16y7 question (0LlY)
The CKP sensor is up inside the distributor. The Crank Fluctuation sensor (CKF) is located by the oil pump. OBD1 ECUs also don't look for this sensor since it was introduced as a component of OBD2.
LSVTEC426
08-13-2007 08:39 AM
pumpkyn
14
10-05-2006 01:39 PM
BigPlansNoMoney
11
11-15-2004 11:49 AM
