D16y7 to D16Y8 manifold problem.
Does anyone have links to a walk through of this swap. My car is at a shop and we are trying to figure out the problem i am having. The car seems to change idel from 1000-1500 and then my check engine light comes on and then sitts at 1500 rpm. The code was for a malfunctioning IAC system. What do we need to do? Again its a d16y7 with a y8 manifold that was off a 99 ex automatic (Holes are pre welded from honda on the back)
Re: D16y7 to D16Y8 manifold problem. (speedehatch)
was youre IACV functioning properly before the swap. when i first started mine it went straight to 2k and bounced back and forth and let it do that for a while, until it settled down. you getting any white smoke out the back end.
Re: D16y7 to D16Y8 manifold problem. (Civiclx)
To be honest i dont know. I left my car at the shop which is 2 hours away. Dont ask. I can find out tommarow though. Which one should i be using?
uindaway
13
11-01-2012 01:05 PM
PetieCivicface
05-05-2008 11:59 AM
suspendedHatch
08-23-2006 08:56 AM
