d16y7 d16y8 fuel injecor compatibility?
Re: d16y7 d16y8 fuel injecor compatibility? (Civiclx)
They do fit, but are not the same injectors. I think the Y7s are 170-180 and the Y8 is a 240. Somebody help me out here.
Re: d16y7 d16y8 fuel injecor compatibility? (solsteeler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsteeler »</TD></TR><TR><TD CLASS="quote">I wanna say they both use the same injectors, but I'm not one hundred percent sure.</TD></TR></TABLE>
I used to think the same thing, but there is a chart floating around here to prove otherwise. I've also compared the two, and they are not the same injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsteeler »</TD></TR><TR><TD CLASS="quote">Learn something new everyday. I stand corrected good sir!</TD></TR></TABLE>
Yeah, I've torn apart a few D series intake mani's (and found out some little stuff like this the hard way), but somebody throw that chart up...I'm having trouble finding it.
Go with the EX injectors. I put the ex injectors in when I did my y8 intake mani swap, and it was running rich, but now I'm b00sted and appreciate the y8 injectors. If you have a VAFC or something to tune it down, run the y8 injectors and tune it. If not I would run the y8 injectors just to be safe anyway.
Re: d16y7 d16y8 fuel injecor compatibility? (Ricey McRicerton)
ok, ill keep the y8 injectors on there, any tips to see if the injectors are going bad? will it throw an injector cel code?
So isn't it true that the ecu determines if your cars runs rich or lean no matter what the injector size is? And that the bigger injector you have the lower the duty cycle which is less strain on the injector? I know bigger injectors flow more fuel but I thought it was dependant on the ecu.
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx »</TD></TR><TR><TD CLASS="quote">so i can interchange them?</TD></TR></TABLE>
yep
yep
Let me ask something within the same question....do you think it's wise to put a 300+cc injector in with a stock(well kind of built) D16Y8? Because I was thinking of doing it later on.
MiG-21 superfan
Re: d16y7 d16y8 fuel injecor compatibility? (JunY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunY »</TD></TR><TR><TD CLASS="quote">Let me ask something within the same question....do you think it's wise to put a 300+cc injector in with a stock(well kind of built) D16Y8? Because I was thinking of doing it later on. </TD></TR></TABLE> Are you boosted or anything? The stock injectors are good up to 170 whp no problem... There is no need for more injector on a d16y8 unless you are spraying or boosting.
bigger, car, civic, compatability, compatibility, d16y7, d16y7d16y8, d16y8, injecters, injectors, lean, minime, run
