d16a6 spun bearing+d16y7 block=?
Ok i have a complete d16a6 with a bad spun rod bearing nd i have a good d16y7 with with no dizzy or fuel rail. What can i do with this? Can i make a runin engine out of what i have ?
Re: d16a6 spun bearing+d16y7 block=?
If the D16Y7 block is good then you can use the head off of your D16A6 on it.
If the D16Y7 is complete, drop it in using the intake and exhaust manifolds off of your D16A6 and use the D16A6's dizzy. Drops right in and runs the same. Manifolds and dizzy bolt right up and there is literally nothing else to do.
just reuse the bottom end of the Y7 and the top end of the A6 direct bolt on make sure to replace the headstuds while ur at it unless u want a blown headgasket because of the factory bolts are not realy re-torque friendly
