d16a6 in eg 4 door,no bottom end power
ok i got a 92 eg 4 door with a simi built d16a6, head has been decked, three angle valve job, stage two cam, i put a hondata intake manifold gasket, fadaza flywheel, dx trans mission, i am throwin a tps code, change the tps out and still throwin the code, running a stock p28, yes i know i should run a po6 but my ? is when i take off the car will hardly make it up a hill,, i have to ride the clutch until i get up to about 2-3k rpms and then the car will take off, but in a cruse the car will fall on its face and is really really weak,, any ideals.. the car has been sitting for 5 years and did have bad gas in it,, but i was wondering if i change ecus will the car run better? and i also beleve the p28 could be messed up because the car it was in the guy ran it and change batterys one day and had the battery termalls switch around and maybe blew the ecu
jxhxb
42
12-09-2008 08:53 PM
