D16 with sputter??
Old 07-09-2019, 08:47 AM
zaxfire69's Avatar
Default D16 with sputter??
I have a d16 that will not run right. I have changed distributor, wires, plugs, fuel pump, fuel filter and still this engine doesn't want to run right. The timing is set correctly. I have ran just about every type of fuel you can imagine through it...Non-ethanol 87, 93 and ethanol 87, 93 nothing will make it run smoothly. It has an AEM cold air intake, 4 into 1 header and full exhaust. I am about ready to pull it out and run a K swap if I can't fix this issue. When I put it under a load it acts like it wants to spit and sputter unless I hold it wide open. Hell that is the only time it runs right is when I hold it wide open. I just want it to run smoothly again. What would you do?
zaxfire69 is offline
Old 07-09-2019, 10:37 AM
muellersfan's Avatar
Default Re: D16 with sputter??
Post the CEL codes.
What specific car and engine?
muellersfan is offline
Old 07-09-2019, 12:42 PM
Loves Tossing Salad
09chaplak's Avatar
Check for a loose ground, especially on the thermostat.
09chaplak is offline
Old 07-09-2019, 08:41 PM
MAP sensor issue ???
JRCivic1 is offline
Old 07-10-2019, 06:33 AM
zaxfire69's Avatar
The car is a 96 Honda Civic Dx with a JDM Non-Vtec ZC or D16a. It starts right up runs nice until it gets some temp into it. That is when the stutter starts. Usually when I am cruising at highway speeds at a steady throttle. It doesn't like it when I am maintaining a steady throttle or speed. It bucks until I give it more gas which is usually full throttle.
Old 07-10-2019, 06:34 AM
CEL codes?
Does the problem go away if you unplug the O2 sensor.
  • Ask a Question
Question Title:
Description:
