d16 build
d16 build
so. i tried searching but i dont know what to look for. i just have some simeple questions though. i also checked out turbod16.com
1) do crank bearings have to be replaced to boost a d16 vtech safely?
2)What else do i have to do to the motor other then cam and gears for turbo.
3)what happens if you dont tune a boosted motor?
4)whats a reasonable goal to look for when it comes to horsepower and torque?
Re: d16 build (biggjerryc)
ok heres some words to live by "you do one thing you must compensate with another" you need to tune a turbo or you will run lean and burn it up, as far as internals you can run 6 to 8 psi safetly on stock bottom end (some people say 10psi but i personally 7 psi is enough to feed it and not cause too much wear on a stock bottom end) you will need to beef up your fuel system and ignition system, ect just remember the first line
