D15B7 to Z6 swap?
Okay heres the deal I got a 92 Eg hatch Auto with a d16b7 in it.
Im swapping to a Z6 manual conversion. Heres the parts I have so far. I am wondering what else I need to complete it. Can I use parts of my d15b7 such as alternator & mounting bracket, Dizzy, engine harness, heater piping, etc for the z6 swap? Z6 Complete Head & Block 93 ex tranny Clutch Disc Clutch Pressure Plate Pilot Bearing Throw out bearing Flywheel bolts Pressure plate bolts Release fork and boot Manual Speed Sensor Clutch inspection plate Manual transmission starter with bolts Flywheel Clutch Master Cylinder with reservoir Clutch Slave Cylinder Clutch Lines 93 ex Manual pedal Assembly Civic auto to manual conversion mounts. Manual p28 ECU 93 ex civic manual Shift Linkage Manual Throttle cable |
Re: D15B7 to Z6 swap?
If you can find a 92-95 ex/SI engine harness your VTEC will be plug and play
Originally Posted by HondaPartsHero
(Post 47998777)
you can use everything except dizzy plugs and wires. im sure the b7 wires would work but they would probably make the car run like garbage. might as well do the full tune up while your at it anyways. your lucky you have a 92 with vtec already wired in. saves a lot of troubles. glwb
Originally Posted by Ghunt521
(Post 47998982)
dont need it i got a dx so it is already there to the ecu, all i have to do it wire vtec right into the harness.
o okay nice, I figured the dizzy wouldn't work. But everything i seem to be okay on and that save me $$$. Hopefully build will be done buy april 13. Gather more parts up now for the swap. Will post build thread soon
