d15b7 turboing questions
i want to turbo my d15b7.. i would only run 5-7psi of boost. i want to get a ebay kit (dont bash me)..
this is the turbo
http://cgi.ebay.com/ebaymotors/92-95...Q5fAccessories
this is the pipeing and intercooler
http://cgi.ebay.com/ebaymotors/2-5-P...Q5fAccessories
or..... should i get this
http://cgi.ebay.com/ebaymotors/93-97...Q5fAccessories
THIS IS THE BOLT ON KIT
what else do i need. if any one on here has a whole set up for sale let me know
any help would be great thanks!
this is the turbo
Re: d15b7 turboing questions
not necessarily ive never ran one on my set up and have never had problems but im not running a ebay turbo either im running a gt28r. main thing running these ebay turbos most people are running them with oil restrictors with success. i don recall the size you would need though
ok also if i do a mini me swap could i use this intake manifold
http://cgi.ebay.com/ebaymotors/SKUNK...Q5fAccessories
yes but those skunk 2 manifold are known for their nipples to fall off maybe thats just one person that had a fluke incident i read it on turbod16 where i like to get a lot of my info on turbo d series . im using a edelbrock performer x manifold...lil better quality
Retired Moderator
Heres 2 words of wsdom when it comes to throwing on a turbo kit:
Fast
Cheap
Relaible
^^ pick 2 and the 3rd is what its not.
If u try and save a buck, will cost you 2
Keep those in mind when you build your engine, and that should help you make the right decisions.
Fast
Cheap
Relaible
Here is a thread that was posted a while back about ebay setups. This person actually found a seller that had a kit that, for the most part, had parts that worked.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/my-ebay-kitted-2000-4dr-ls-swap-2760152/
Read through it and you will see what parts have been found to fail. Obviously the turbo is typically one of the weak links in an ebay kit. I would never use one personally, but some people have used them on low boost for quite a while.
Just make sure to get a good tune when all is said and done. Good luck.
showtymers619
01-22-2008 09:44 AM
