d15b7 swap question
d15b7 swap question
I have a d15 on an auto trans I'm swapping onto my 5spd eg.(still has old blown d15) motor.
Do I need to transfer any parts over to the new engine? Or its just plug and play?
Should I flush my mtf out? No grinds shifts smoothly before motor blew.
Probably a stupid question but when the Axel leaks what is it?transmission fluid right??
Will be doing full tune up oil change and radiator flush.
Re: d15b7 swap question
...and the year and trim of your Civic is...?
Click the forum Rules link in my signature.
Post pictures of the current blown engine and the replacement you are swapping. What year Civic does the replacement engine come from?
Blown motor is from 95 civic DX sedan
New motor is from 92 civic DX sedan
I'm only swapping the engine.
I took the 5spd trans and blown motor out.
Now I'm going to pull the new one out and slap it on the 5spd trans. Do I need to change parts from 5spd engine to automatics engine?
The motors are the same. Swap the wiring harness from the manual engine to the new one
Make sure the map sensor is mounted on the tb or not on both engines. Some had firewall mounted some had tb mounted.
bboixtc
12
03-14-2014 05:35 PM
Mikeyb918
12
09-20-2013 05:27 AM
steede
08-20-2009 11:52 AM
