Rewiring D16z6 distributor to OBD2?
Sushi Buffet Champion
I have a D16z6 that's going into a 97 hatch. Is it possible to re-pin the wires to OBD2 specs? I still have my D16y7 distributor with the plug still in tact. Can I re-pin the D16z6 pins into the D16y7 plug? TIA.
96-00
C120
pin#-dist side color-function-harness side color
1-Yel/Grn-ECU Ignition signal-Yel/Grn
2-Lt Blu(or Blu/Grn)-CKP signal-Blu
3-Orn/Blu-TDC signal-Grn
4-Orn-CYP signal-Yel
6-LtBlu/Yel(or Blu/Yel or Wht)-CKP gnd-wht
7-Wht/Blu-TDC gnd-Red
8-Wht(or Blk)-CYP gnd-Blk
9-Blu-Engine speed output-Blu
10-Blk/Yel-coil power-Blk/Yel
92-95
C107
2-Blu/Grn-CKP signal-Blu/Grn
3-Orn/Blu-TDC signal-ORN/Blu
4-Orn-CYL signal-Orn
6-Blu/Yel-CKP gnd-Blu/Yel
7-Wht/Blu-TDC gnd-Wht/Blu
8-Wht-CYL gnd-Wht
You have to move two wires from/to another plug C106(OBD1), pin1, Blu-Tach output, and Blk/Yel-coil power.
C120
92-95
C107
8-Wht-CYL gnd-Wht
1 Post
Re: (Relic1)
In reality all you are doing is matching up the wire colors. It's not that hard.
OBD-1 and OBD-2 distributors operate by using the exact same signals, so you don't need to change any internals. In other words, both distributors are essentially the same, but they just have different plugs.
Re: Rewiring D16z6 distributor to OBD2? (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi »</TD></TR><TR><TD CLASS="quote">if you do that, your timing is going to be off. so if you do use the z6 dizzy, youll have to time it with the gun.</TD></TR></TABLE>
As long as I correct it with a timing gun right? Any down falls of a D16z6 motor in an OBD2 car?
krysted9354
06-02-2011 08:45 PM
Import13alla
04-09-2004 06:24 PM
