D15b7 help!!!!
D15b7 help!!!!
yeah i got a 1994 civic with a bone stock d15b7 non-vtec motor. when i bought this car is had a broken injector clip. the car ran fine and all but it just bothered me that the clip was broken, so i changed it. i replaced the clip and the car starts up just the way its suppose to. so i took it for a test drive. when i had it in first gear and gave it some gas it went then it dies.. then when i let go of the gas a little bit it goes. i cant go full throttle no half throttle. what could be the problem? i didnt touch anything else and i unplugged the battery too. HELP...
Re: D15b7 help!!!! (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">bump for help </TD></TR></TABLE>
thanks man i need it. my daily needs to be fixed....
Re: (vrrodri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrrodri »</TD></TR><TR><TD CLASS="quote">maybe you disconnected the electrical connector on the injector? double check it...</TD></TR></TABLE>
what do you mean by that?
Re: (IOSUA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IOSUA »</TD></TR><TR><TD CLASS="quote">anyone else got any ideas? </TD></TR></TABLE>
Re: (ShortyzKustomz)
yeah i checked all vaccum lines and all. i thought it might of been my TPS sensor, so i unplugged it and it ran the same. do you think its might be that?
Re: (sohcvtec1995)
nope, every injector clip is fine. i disconnected them one by one and the motor changed idle. so yeah, im pretty sure the clips are ok. anything else i should try??
Re: (95civiccpdx)
tried it again. its the same. im thinking my TPS might of went bad, or somethings wrong with my dizzy. i dont know what might of went wrong....
Re: (IOSUA)
changed the spark plug wires and spark plugs. changed throttle body and gasket, changed injectors and fuel pressure regulator. and still no luck.
Re: (IOSUA)
theres a vacuum line under neithe the manifold check that. i ran my car for a year with it unplugged. do you hear a suction when you turn it off?
