d15b wont rev past 4k
Old 10-26-2010, 12:12 PM
v8killaz's Avatar
Default d15b wont rev past 4k
i searched with no luck alot of people seem to have the problem but never update how it was fixed
heres the situation
d15b in a obdI del sol
car starts great, runs fine other than having very little power, idles fine, spark in all cylinders
cel is on for iat(not plugged), vtec(not plugged), o2(not plugged)
using a p72 ecu for now, but same thing with multiple ecu's.
the car seems to be lagging in power, timing is fine. I rev it in neutral or moving the car wont rev past 4k
im using a nonvtec harness for now.
anyone have an idea what it could be. I was thinking dizzy but we changed it temporary and same thing
im lost
Old 10-27-2010, 10:39 AM
v8killaz's Avatar
Default Re: d15b wont rev past 4k
bump
Old 10-27-2010, 06:40 PM
havok6969's Avatar
your ecu is in limp mode, that means your ecu is looking for components and cant find it so it puts it self to safe mode so it prevents the engine from further dmgs. or something could be plug in a wrong pin in the obd1 connections
Old 10-27-2010, 10:11 PM
eg6stroker's Avatar
ttt
Old 10-28-2010, 04:48 PM
v8killaz's Avatar
been through about 10 ecu's same thing
unplugged everything and still the same thing
even disabled all the sensors through my neptune ecu still the same
i know its electrical but i seem to be lost at what it could be. grounds are good,
I do have a feeling its in limp mode but the map is good switched it out the other day, and the dizzy was switched temperarly and still same thing.
If i take off all the sensors and leave the main ones on
switched the engine harness too. could thee be a short before the engine harness
Old 10-29-2010, 11:52 AM
v8killaz's Avatar
made a mistake this is a d15z motor
still the same problem
Old 10-30-2010, 09:40 AM
v8killaz's Avatar
what dude
its not cheap it blows through gas like nothing
worse than my boosted y8
Old 10-30-2010, 07:36 PM
v8killaz's Avatar
Originally Posted by foo fighters
then somethins wrong, my d15b 4dr can beat my friends b18a 3dr and i still get 28-32 mpg.your ecu is stuck in open loop mode, hook up your o2 sensor (why isnt your 02 sensor hooked up???)
look bro diregard the ecu's and running open loop
it should run fine in open loop as well
we ran a neptune and every map their could be including the d15z map
that made absolutly no difference. we disabled o2 and vtec and everything still runs shitty and wont rev past 3k
ive got a video of it ill post up
Old 10-30-2010, 08:54 PM
YORSH's Avatar
do you already check your ckp sensor???
when i bought my 95 eg with d15b8 engine didn't pas 3k and have no cel, because this sensor was unplugged
Old 10-30-2010, 11:03 PM
DCRB's Avatar
you absolutely SURE timing is fine? i put my belt on a tooth off once and it looked fine but was gutless and wouldn't rev for ****.
Old 10-31-2010, 06:32 AM
KamikazeDR's Avatar
Wich vtec code is trowing the ECU 21 or 22 if is the Vtec Pressure switch i have a trick so u cant get rid of this code just using a relay
Old 10-31-2010, 10:30 AM
v8killaz's Avatar
LOOK BRO, the d15z1 v-tec-E uses a v-tec cam that ONLY saves you gas! e stands for economy. that motor can only run off its stock basemap. How the hell are you runnin v-tec basemaps w/out hookin up your v-tec and oil pressure switch???? and expecting a positive differance? how is it blowin through gas if it doesn't rev past 4k??? FYI d15z1 has 92hp/ d15b7 has 102hp. d15b7 w/ d16z6 head and a p28 = good times.
i think you fail to read my post, ive ran the motor on its stock basemap countless times with no difference at all. and it doesnt matter what ecu i throw on it it should still at least run and rev past 3k. My neptune is in my other car and i cannot keep burning basemaps on it so im left using a p28. vtec has nothing to do with anything. ive manually engaged vtec and no difference in rpm just sound. I dont know why it blows through gas, thats what im trying to figure out it all relates to one problem.
22
i dont need to get rid of the code
i dont beileve it has anything to do with not revving past 3k and running shitty
did a compression test today also and came out good 180-180-160-180
checked timing dead on, checked the dizzy seems to be good
Old 11-06-2010, 05:03 AM
foo fighters's Avatar
A BOOSTED Y8, B16A2, And your worried about sohc v-tec's retarded little brother??? i've never had a turbo or dohc v-tec but if i did, i wouldn't be cuttin corners now by getting a d15z1. i don't have them and i still got the RIGHT d15b. Your not going to get good answers if you UNPLUG O2 sensor,oil Pressure switch,then troubleshoot. But if you think you dont need 'em...
Old 11-06-2010, 07:15 AM
v8killaz's Avatar
yeah i know wont get good answers on h-t
i need to join realhommadeturbo lol
but the cars not mine its my freinds, i tell him its junk he thinks it worth like 3k i wouldnt even pay 300 for it
he says if i fix it i can borrow it. i need to fix it so i can build my d series
Old 11-06-2010, 08:13 AM
djslim23's Avatar
makes no sense..you went through 10 ecu's before making sure everything was hooked up right? this thread is pointless. why dont you fix all your CEL's before posting a Help me please thread....lazy ***
Old 11-06-2010, 10:58 AM
H22AFerio's Avatar
are you running a non-vtec Dizzy? I was rinning a not vtec dizzy when I did my mini-me swap back in high school and it would not rev past 4k then I swapped on a vtec dizzy and bam it worked fine.
Old 11-06-2010, 11:06 AM
v8killaz's Avatar
well i ran a non vtec ecu and still the same thing
if i run a vtec ecu there is absolutly no difference
Old 11-06-2010, 11:09 AM
v8killaz's Avatar
cels are on because i dont have them plugged in. they turn off as soon as i plug them in and reset the codes. obviously making no difference whatsoever. i have a neptune and s300 and disabled every sensor and still the same.....
dumb ***
Old 11-06-2010, 05:09 PM
Jimster480's Avatar
a d15z is a VTEC-E Motor. Without it turning on the VTEC to open the 4th valve, the motor is going to have serious issues with power and its ability to rev. Also it doesnt matter what ECU you have, because if you have the same sensor problem then each ECU will just go into limp mode.
Old 11-06-2010, 09:59 PM
v8killaz's Avatar
yeah i understand
we had the d15z map and same stuff happened. no codes at all. we had o2 disabled from neptune though
Old 11-06-2010, 10:00 PM
v8killaz's Avatar
here i got a youtube video
http://www.youtube.com/watch?v=NrFxsJ7V8es
Old 11-06-2010, 10:11 PM
y5dunk's Avatar
i have a 96 civic coupe hx. it has the d16y5 setup that comes stock. i am wanting to put a y8 head that i have on my y5 block, what do i have to do to do that and my car run right?
Old 11-07-2010, 10:36 AM
H22AFerio's Avatar
No Im talking about the distrubtor not ecu.
Old 11-07-2010, 11:27 AM
Jimster480's Avatar
Why do you want to put the Y8 head on there? the Y5 head only makes 10HP less and gets alot better fuel economy.
Old 11-07-2010, 11:01 PM
v8killaz's Avatar
yeah im pretty sure im running a vtec dizzy
Quick Reply: d15b wont rev past 4k
