is the D15B a vtec engine?
Re: is the D15B a vtec engine?
we have a shearch engine too...
D16Z6
Found in
1992-1995 Honda Civic Si
1992-1995 Honda Civic EX, EX-V
1992-1995 Honda Civic ESi (European Market)
1993-1995 Honda Del Sol Si (US)
1993-1995 Honda Del Sol ESi (European)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Rod Length : 137MM
Rod/Stroke : 1.52
Compression : 9.2:1
Power : 125 hp (93.2 kW, 127 ps) @ 6600 rpm
Torque : 106 ft·lb (14.7 kg/m, 144 Nm) @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7411 rpm
VTEC Switchover : 4800 rpm[3]
Fuel Control : OBD-1 MPFI
Head Code : P08
ECU Code : P28
[edit] D15B
VTEC
Found in :
1991-1995 Honda Civic VTi EG4 (Japanese Market)
1991-1995 Honda Civic VTi EG8 (Japanese Market)
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke :75,0×84,5 mm
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9,3:1
Power : 130 hp (96.9 kW, 130 ps) @ 6800 rpm
Torque : 103 ft·lbf (14.1 kg/m, 138 Nm) @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Valvetrain : SOHC VTEC (4 valves per cylinder)
VTEC Switchover : 4200 rpm
Head Code : P08
Piston Code: P08-010
Fuel Control : OBD-1 PGM-FI
[edit] D15B (3 stage VTEC)
3-stage VTEC
Found in:
1995-1999 Honda Civic VTi EK3 and Ferio Vi
Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
Power : 128 hp (95.4 kW, 130 ps) @ 7000 rpm
Torque : 102 ft·lbf (14.2 kg/m, 138 Nm) @ 5300 rpm
Valvetrain : SOHC VTEC (3-4 valves per cylinder, depending on rpm)
VTEC Switchover : 2500 rpm (VTEC-E) & 6000 rpm (VTEC)
Fuel Control : OBD-2 MPFI
[edit] D15B
Non-Vtec
Found in :
1988 Honda CRX 1.5X (rare)
Ferio MX (Japanese Market)
Compression : 9.2:1
Power : 106 hp (96.9 kW, 105 ps) @ 6500 rpm
Torque : 95.4 ft·lbf (13.2 kg/m) @ 4500 rpm
Rev limiter : 7400 rpm
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : Dual Carburetor
D16Z6
Found in
Rod Length : 137MM
Rod/Stroke : 1.52
Compression : 9.2:1
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Head Code : P08
ECU Code : P28
[edit] D15B
VTEC
Found in :
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9,3:1
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Head Code : P08
3-stage VTEC
Found in:
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
[edit] D15B
Non-Vtec
Found in :
Compression : 9.2:1
The D15B comes in both a vtec and non-vtec version. It looks like you have the VTEC solenoid. Also, spark plug holes on the front of the engine = VTEC. On the rear = non-VTEC.
On the non-vtec D15B: http://honda.lioness.googlepages.com...15benginenotes
i have 2 ej1's one with Z6 the other with D15b, they are nearly identical cept the Z6 has a lil bigger displacement. keep ur motor and do some work to it. its not worth the swap.
