D15/D16 oil pans, interchangable?
Im just wondering if the d15b7 (92-95 dx engine) and the d16a6 (91 crx si engine) oil pans are interchangable? Im wondering becuase i had teh d15b7 in my car and had the oil pan tapped for the oil return, im now putting a built d16a6 in it and wondering if i can just put the d15b7 oil pan on it so i dont have to retap the pan. TIA
Re: D15/D16 oil pans, interchangable? (ITSTOCK)
I would assume because don't they have the same blocks and most of the parts are the same except heads between some motors, and the internals.
Re: D15/D16 oil pans, interchangable? (ABK)
ya, i dont see why they wouldnt be the same, i think the bolt pattern and what not is teh same and that the d15pan will physically fit on the d16, just not sure if theres ay difference on teh passage inside the pan itself, or if the slopes are any different.
you wonna an easy way to check go to napaonline.com and check if the part numbers for oil pan gasket from 1.5 and 1.6 are the same. I bet you they are but hit us back
its the same im using a d15 right now cuz my z6 is tapped for turbo, people need to post when they have first hand experience, not when they think they know
Re: D15/D16 oil pans, interchangable? (boostedcivichatchbacksi)
D15/D16 pans should work together fine. Blocks are the same...
But now going from a 92-95 oil pan to a 96+ pan will cause problems because of the dipstick location on the different years
yea it will definately fit because d series all bolt up as long as its not custom made just like all the b series parts being able to bolt up
