d series skunk 2 intake mani install
i just installed my skunk2 mani on my 93 civic hatch with a d16z6 but now im gettin a wierd idle from 500 to 1500 -2000 anyone have a video or tutorial on how to install this so it idles perfect
Re: d series skunk 2 intake mani install
ok cause i changed my throttle body and all i did was turn the sensor on the throttle all the way to the left and the car ran fine. it idle at 750 constant unless its heating up then i idles at like 1000
as far as your idle problem, make sure u bled the cooling system, make sure the TPS is calibrated, check for vacuum leaks along the manifold and throttle body, make sure the throttle cable isnt holding the throttle body open, make sure all sensors are plugged in. Also are u throwing a Check Engine Light?
throttle blade might not be adjusted right. making it idle weird. is the throttle body a bigger one then the one it had before?
Sounds like a vacuum leak. OP, on the IM runner which goes to Cylinder one, there is a opening for a sensor on certain applications. Is this plugged? This is the same problem I ran into when installed the S2 IM a little while ago.
hondastrtracr
13
06-24-2007 10:17 AM
