d series gods HELP!!!
on a d16z6 on the top of the block behind the middle head stud there is a hole. the hole goes down to the oil pressure sensor. my question is there suppose to be a orfice in that hole? i put a new oil pump and oil pressure senser both oem from honda and my oil light was still lighting up. i pulled the head off to check and see if one was there and it wasnt. a good friend of mine said that he was almost positive i am suposse to have one there and thats why my oil light was on. anyone know anything about this??? HHHEEELLLPP..... thanx drew
Re: (tatmark1)
in that hole its opened wider about a 1/2 inch more so it looks like a orfise will fit in there. on b-series they have one cause i looked at one. are d-series suposse to have one too?
Re: (tatmark1)
Your block is correct... you don't need that "orfice"/ plug... with it plugged up your vtec wont work...
you probably just didn't build up enough oil pressure... unhook the dizzy and crank the car over until you build up some oil pressure, then plug it up and bam should start and oil light should be off, unless you put the oil pump in wrong.
Re: (EGRhatch)
well i'm gonna put the head back on and since i dont have this orfice i'm not gonna worry about it. ill do a pressure test and start from there. thanx for the info EGRhatch
Re: (delsoldrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsoldrew »</TD></TR><TR><TD CLASS="quote">put the head back on and since i dont have this orfice i'm not gonna worry about it. </TD></TR></TABLE>
wow
wow
Re: (slowEKcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowEKcoupe »</TD></TR><TR><TD CLASS="quote">
wow</TD></TR></TABLE>
well i said that because i know now that wasnt the problem
spiffy_civic
14
05-01-2011 12:59 AM
EJ1_Can2
10-06-2010 10:48 AM
