d series cam. opinions
i searched on this topic before with no luck so here i am. so i am looking into buying a new cam for my d16z6 and i was wondering which is best of these three, crane, crower, or skunk2? and where can i buy these, i can't find a good site anywhere! and is $175 a good price for a shop to install and time it? i don't think i could handle it personally. thanks
Re: d series cam. opinions (tek_civic)
i would shop around for the price. depends if it's a shop that u know does good work. have u looked into a zex cam? they make a good cam for the street.
Solbros Owns Me
Re: d series cam. opinions (tominos)
I have ZEX cam, the street/strip one, I think it's 59300 or something. Anyway, it's a pretty good cam. I haven';t put on my gear yet, so my powerband isnt where I want it, but in the low and mid range, the power has deffinately improved. My powerband tends to level off after 5500 though, so I'll need to tune it to my liking. The response is great, the sound is MUCH louder, and the low end torque is WAY better. I think 175 would be too much for the install, unless you have them put in a new timing belt and H20 pump at the same time. You figure 65 bucks/hour, and the cam install take around 1 1/2 to 2 hours. So, have them do the little extras, plus they'll need to adjust your valves, etc. I would look into the Skunk 2 cams they have coming out.
Re: d series cam. opinions (Emerica)
I have a JG303 cam in my D16 and it makes a lot of power from 4500 up to redline. There was a drop in low end horsepower but not by much. The idle is smooth accept for a little hicup every now and then but it's tolerable.
1 Post
Re: d series cam. opinions (Kail18)
after you get your cam.. there is so many options to do after. We should be carrying the SKUNK sohc line as well as the Edelbrock manifold. and the new BISIMOTO header. with these bolt ons and the block work that can be done.. you'llhave a sick sohc setup.
Wil
Wil
Re: d series cam. opinions (exospeedAMcrx)
let me know when your d series section gets up, just send me a pm or i will just check every now and then(probibly then though).
Re: d series cam. opinions (derrickcxhatch)
gude, JG, ZEX are all good cams, whatever you do, DON'T BUY A CRANE CAM!!!! it will fall apart on you. and as far as gears go, i would go with a skunk gear, don't do an aem, due to the fact that the screws are known to back themselves out and the gear will adjust on ya
what shop is doing the install?
goldeneagle has a nice line of d-series components coming out. one of which is a cam gear. believe that they also have an intake manifold on its way. http://www.goldeneaglemfg.com
Solbros Owns Me
my originol price quote is from ASP in glenwood springs, but i called up cruise control in Rifle(on the way to grand junction), and they said that would cost about $130 or less, so i would use them. i have ordered the cam and i am now contemplating doing it myself, it'll be good for me. i should get the cam hopefully by this weekend and if the schedual keeps up i will attempt it on sunday.
If you need help shot me an im I have never put a cam in my self but hell I can help some how. But this weekend I am putting in my exedy clutch and my srr flywheel.
[Modified by derrickcxhatch, 2:41 AM 1/30/2003]
