d to b series swap, car and year application
Re: d to b series swap, car and year application
Any engine is possible...if your looking for plug and play...99-00 b16a2 or 96+ GSR....
Search on google for more info...
The Grumpiest
You can put anything into any car you want. Seeing as how some of the 6th gen Civics and come Del Sols came with B-series why do you feel the need to even ask this question?
Check the FAQs.
Check the FAQs.
Wondering what cars to look for at junkyard that I could pull better motor out of and swap in for better horsepower, they charge 150 a block with head and some components
From everything I'm researching d series motor I got can't put down that much HP, I did mini me swap, skunk2 IM, header, Cai, exhaust, advanced timing 2 degrees, auto trans and don't know what my next step is? Head work? Block work? Swap? I'm pretty mechanically inclined so whatever I need to buy I can install myself
Well you will get nowhere with all motor D series...especially with AUTO trans! Either swap 5spd and boost the D or swap it for a B series...I would just look for a b16a2 from a 99-00 civic SI or find a B18 from a 96+ integra.
Id boost but there r so many different post on turboing and I'm lost on it, If I could find a full kit somewhere with Instructions would be nice
pm4nudes
For the American market you can pull b series motors from 99-00 Civic Si, 90-01 Integras and 95-01 CRVs. Those are the cars you mainly want to look for. As for what you have right now, I'd convert to a manual transmission and run a turbo set-up if you're looking for a bit more power.
Here is the lowdown on B swaps:
90-93 Integra = B18A1. These motors are OBD0, and are only really good if there is a lot of them in your area so you can get parts easy.
94-01 Integra LS/RS/GS = B18B1. These motors are OBD1 up to 95, then OBD2 from 96+. They're non vtec, and a good motor if your looking to boost or just a cheap swap. They're cheap and pretty easy to come by.
94-01 Integra GSR = B18C1. Vtec, more expensive than the B1, but good if your looking to go all motor, or a more expensive boosted build.
99-00 Civic Si = B16A2. Vtec, doesn't have as much power as the C1, cheaper than the C1, but a bit harder to find parts for since there weren't as many years of them, which means not as many out there.
Those are about all your options as far as B swaps go. I would go 96+ B1 swap if your looking for affordability, or a 96+ C1 swap if your looking for more power. The B16A2's tend to be overpriced, at least in my area. I've never driven a Civic with one, but I've heard they're pretty gutless, and not exactly the best unless you plan on building it. Just my .02 . .
prcivic91
112
09-12-2006 12:01 AM
