cylinder 3!?
cylinder 3!?
after i do a run on the track i notice that my no.3 cylinder stops getting a spark, i checked with the old screwdriver test didnt shock me.then i tested it at night under the same cunditions and again no spark.after a few minutes it goes back to normal .whats goin on!?
setup d16z6 turbo 7psi im also throwing a cel 41(o2 heater) i know how to fix that but ya help
Re: cylinder 3!? (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned »</TD></TR><TR><TD CLASS="quote">yep ive checked all of the above</TD></TR></TABLE>
check again...
its one of those things.
swap wires from 3 and 4 and see if the problem follows.
platinum.
check again...
platinum.
Re: cylinder 3!? (platinum00)
ok im not dumb ,but thanks .ill try to say it again after a run the 3rd cylinder from the left stops getting a spark,and i check at the destributer* cap (because i went out and bought a stupid clear cap last night)i can see that it stops getting a the spark.and after a few minutes it goes back to normal.does it matter that vtec hasnt worked for a while?(oil preesure)
.....bump because i hope some1 can help me
