CV Boots for 93 Del Sol
Old 06-04-2009, 07:12 AM
New User
rcgtr's Avatar
Default CV Boots for 93 Del Sol
I just bought a 93 del sol S with 140k miles that needs a lot of TLC. For starts the boots are cracked on the CVJs, ball joints, tie rods, etc. The CVJs are not clattering so I'd like to just change the boots. Where should I look for high quality CV boots? i'm fine going with oem if that's clearly the best. I only want to do this once. :-)
Also the inner CV joints are painted green (the joint, not the boot). Does this sound like original joints or have they been swapped out by a previous owner?
-RC
Old 06-04-2009, 07:40 AM
I'm not Rick!
rick_rabies's Avatar
Default Re: CV Boots for 93 Del Sol
i would just replace them, you will thank your self later.
Old 06-04-2009, 08:26 AM
New User
rcgtr's Avatar
I'm guessing new halfshafts are pricey, and I've read a few stories of reman halfshafts going south within a year or two, probably due to marginally worn out CVs being re-used.
I haven't done CV boots in years. Are the reman units generally good quality these days? I certainly like the simplicity of swapping out halfshafts. It's a pain getting all the old grease out of the joints before putting on new boots.
-RC
Old 06-04-2009, 08:37 AM
I'm not Rick!
they are fairly cheap. you could look around localy and seee if anyone has some for sale. if they are bad, just replace them, the are cheap enough i would bother trying to fix them.
Old 06-04-2009, 01:47 PM
New User
rcgtr's Avatar
Wow, it's been a long time since I priced these things. I checked and it's $70 per shaft, new, locally. It's hard to justify changing boots at that price.
-RC
Little Timmy
05-18-2015 07:44 AM
Johnoolo
11-08-2013 09:30 AM
Kod Sol
10-06-2010 06:59 PM
DC2_Jspec
07-21-2002 12:20 AM
Quick Reply: CV Boots for 93 Del Sol
