is it the cv boot?
recently a sqeaking noise started coming from my rear left tire. it starts when i start driving and if i tap on the breaks it will go away. im not sure what it is. i talked to a friend and he said it was my cv boot and i could change it myself. someone else told me id need to get a whole new axle. i dont want to take it to a shop if i can fix this problem by myself. can anyone pin point what the problem is?
Re: is it the cv boot? (jaealdana)
You only have CVs in the front of the car. Don't listen to your friend, he obviously knows nothing.
Does the noise happen when you hit the brakes? Does the noise go away completely after you tap the brakes? (for the rest of the time that your driving) |
not your cv boot if in the rear... unless you're driving a 4wd civic...
it might be your brake pads sticking or something... |
Re: is it the cv boot? (pgpunkguy)
well what do i do about that? haha im a girl. im trying my best to understand whats going on. thats what i was thinking, it might be the brakes. so do i just need to change them? sometimes it kinda sounds like metal is grinding.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaealdana »</TD></TR><TR><TD CLASS="quote">sometimes it kinda sounds like metal is grinding. </TD></TR></TABLE>
Does this happen while you are hitting the brakes? Drum or dics rear brakes? |
Re: is it the cv boot? (fakemike)
the noise goes away when i tap on the brakes. it goes away for quite some time too.
when i hear the metal grinding sound thats from when i hear it sqeaking. it sounds like both, not when i hit the breaks. whats drum or dics rear brakes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fakemike »</TD></TR><TR><TD CLASS="quote">Does this happen while you are hitting the brakes?
Drum or dics rear brakes?</TD></TR></TABLE> pretty sure the si's have rear disc brakes EDIT: haha... i got confused w/ another post... anyway, rear discs will look like the front brakes with a metal disc (rotor) and a brake caliper on one side... drums just look like a black metal bowl behind your wheels (looks different from the front) |
i would look into getting your rear brakes checked. it COULD be a bad wheel bearing, but i doubt it
ok thanks. do i need to take it to a shop then? or is it easy enough to have checked by myself or my stepdad?
oh and is it bad to be driving my car around until its fixed? |
it's something that can be done at home if you know what ur doing. maybe your step-dad is competant enough...
if you have rear drums (which is usually the case), sometimes they're a pain to crack open to see of the brake shoes are doing ok... |
so if there IS a problem with my brakes all i do is replace them?
