cv axles gap question
Re: cv axles gap question
1/3 of an inch seams like alot tho.
take them out and make sure everything is ok with the splines and make sure the clips are still on the ends of them. i have seen those clips come off in the diff and make the axles not go in all the way.
okay thanx i will take them off and put them on again. this is why the whole disk wiggles right? is the 32 mm bolt on the axles the only thing that holds the disks so they wont wiggle.
the axle nut does not hold your rotor on. The wheels does. From the factory you can note that there are little screws that honda uses to keep them on during the manufacturing process
