Curb marks on rims
Re: Curb marks on rims (Nader_D)
its when u hit the curb with the side of your rim while taking a turn. they look like,well um **** thank goodness i make wide enough turns to stay away from the curbs.
no it's chunks of the lip of the wheel that get worn off when rubbing against a curb or whatever else...
I'll post a pic in a minute or two....
Re: Curb marks on rims (sting94112)
it depends on how bad you hit the curb. If you hit it at a slower speed, than it will probably leave a small scratch which probably will be un-noticeable at first glance. If you hit the curb at a decent speed, than you will leave a deeper and more damaging scratch. Use your imagination a bit and you should be able to envision it in your head....
like this
hahah nah just playing. it scratches the lip of the wheel up pretty bad on like a polished lip its not as bad as say a bronze or any painted wheel
Re: Curb marks on rims (WongFeihung)
ok heres the main question ill skip beating around the bush
if im gonna paint the rims, will these marks affect it?
thanks
thanks
If you have the curb damage and there scratched up, sand the scratches a little bit if you plan on painting them then it'll be like you never had the damage.
Re: Curb marks on rims (KiDSoL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KiDSoL »</TD></TR><TR><TD CLASS="quote">If you have the curb damage and there scratched up, sand the scratches a little bit if you plan on painting them then it'll be like you never had the damage. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 »</TD></TR><TR><TD CLASS="quote">if they are really deep yes</TD></TR></TABLE>
if the scratches are deep they will be noticeable after the wheel is painted... not so noticeable but it will definitely be visable.
Use a file... it goes faster and comes out looking decent...
Painting them will certainly reduce the noticablity of the curbage... but it won't make it go away...
even filing or sanding will leave it as noticably un-even on the lip...
I don't have any pictures to post... I thought I had some from work on my camera but I don't...
Sorry.
Sorry.
jamaicantourist
08-14-2009 04:16 PM
