air compressor
Old 12-15-2004, 07:59 PM
komat's Avatar
Default air compressor
im planning to get an air compressor to work on my car. But i dont know which one to get. theres so many of them. currently im looking at this from sears. http://www.sears.com/sr/javasr...70000
what do you guys think
if link doesnt work go to sears.com and search for Craftsman 33 gal. Vertical Portable Tank Compressor, 6 hp.
Old 12-15-2004, 08:05 PM
Mario.'s Avatar
Default Re: air compressor (komat)
I use one of less size and hp, and it works reasonably well. Great for impact air ratchet... prolly wouldn't use it for something that requires a lot of air. But for me, as an enthusiast, this is great for basic repairs and upgrades. I spent $200 on my "Husky" setup from Home Depot. Call it ghetto or cheap, but as a high school student really wasn't looking for the Snap-On adventure.
Old 12-15-2004, 08:07 PM
snoochtodanooch's Avatar
get whatever you can afford, if your only doing work by yourself, your not going to have that big of a duty cycle. That would be fine though, price seems good, plus you get the tools
Old 12-15-2004, 08:08 PM
Electrician
Deemeetree's Avatar
Wrong forum.
I work at Sears. The compressor itself is a good unit to work with. Has good SCFM rating. But, the impact wrench and air ratchet suck donkey *****. Don't think you're going to be breaking crank pulley bolts anytime soon.
SOHC4life 96's Avatar
Default Re: air compressor (snoochtodanooch)
That is a good compressor for working on a car. I plan on getting it after x-mas. Sears employee discount 0wnz.
Old 12-15-2004, 08:10 PM
komat's Avatar
i have a friend that works at sears. may just get her to buy it for me
Old 12-15-2004, 08:12 PM
Electrician
Deemeetree's Avatar
Default Re: air compressor (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life &raquo;</TD></TR><TR><TD CLASS="quote">That is a good compressor for working on a car. I plan on getting it after x-mas. Sears employee discount 0wnz. </TD></TR></TABLE>
w0rd
10% plus a ****-load of $5 and $10 coupons...keep it on the DL though.
Old 12-15-2004, 08:14 PM
Default Re: air compressor (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">i have a friend that works at sears. may just get her to buy it for me</TD></TR></TABLE>
And get her fired while your at it too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">...keep it on the DL though. </TD></TR></TABLE>
you better believe it
Old 12-15-2004, 08:26 PM
Electrician
Deemeetree's Avatar
Indeed.
She can't buy anything for friends. Only herself or immediate family members (IE. mom and dad).
I pretty much got in trouble for buying 5 refridgerators and 5 stoves/ranges. They're all for my dad's apartment complex. I had to proove it to them. Thank God I'm still there...
Old 12-15-2004, 09:30 PM
komat's Avatar
Default Re: (Dimi)
are the tools weak to do the crank pully or the compressor??
im thinking about picking it up tomrorow. for now i just need to remove some bolts to lower my car
Old 12-15-2004, 09:33 PM
DohcSide's Avatar
around 2 hp is good enough its not like your gonna unscrew big 4 pound nutz or anythign are you?
Old 12-15-2004, 09:36 PM
komat's Avatar
Default Re: air compressor (DohcSide)
crank pulley is probably the hardest to remove so i need something that has just enough power to remove it. what hp is good enough 3hp??
what Impact Wrench do you recommend to
Old 12-24-2004, 05:15 PM
4potnick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">crank pulley is probably the hardest to remove so i need something that has just enough power to remove it. what hp is good enough 3hp??
what Impact Wrench do you recommend to</TD></TR></TABLE>Also interested about the crank pulley? I will be picking one up next week.
Old 12-24-2004, 06:41 PM
RTFM
v4lu3s's Avatar
good choice its as much as you can do without getting 220 volts n the garage. i use it and it does 90 percent of what i do. the rest a big breaker works.
Old 12-24-2004, 07:09 PM
Dan GSR's Avatar
Default Re: (v4lu3s)
the 33 gal is decent
I have this one at my house
60 gal, 175psi, i like it better than the smaller tank, it doesn't run out of air as quick
http://www.sears.com/sr/javasr...ssors
along with this impact gun
excellent gun, i'm very happy with it
http://www.sears.com/sr/javasr...Tools
it does 800 ft/lbs of torque
ive only had one instance where a crank bolt wouldn't come off
I couldn't belive it
MugenEg
Paint and Body
01-07-2010 09:28 AM
stackz
Welding / Fabrication
03-16-2006 07:04 AM
rasinhell
15
11-24-2004 06:46 AM
AzntaggeR
08-06-2003 09:29 AM
mikecel79
04-28-2002 09:36 PM
Quick Reply: air compressor
