CTR ECU in JDM OBD1 B16A
I am in talks with someone who is selling a B16B JDM ECU, and I read in another FAQ thread that this will be able to connect directly to my EK's EX harness and not need any VTPS wiring or anything of the sort, is this correct? Currently I run an OBD1 ecu coneccted to ex harness via a conversion harness, so obviously the VTPS wiring was done to the harness already. Will this interfere with the CTR ECU, even though this ECU does not look for VTPS signal? Just trying to verify before I purchase...
Thanks |
Re: CTR ECU in JDM OBD1 B16A
Bump
Why would you want a CTR ecu??? Are you running 11.0:1 compression???
Get a Hondata S300 and you can run any motor setup from here on in, |
