CTR/B20 swap....
CTR/B20 swap....
Does anyone have experience with a B20b/z block & CTR head swap? I am about to purchase a B20 longblock to begin my "Project Swap". I plan on staying N/A and using all stock internals (modified B20 pistons, B20 rods & crank, ctr head, etc...) Its gonna get dropped into an EK hatch. Anyone with this setup have some 1/4mi. times or dyno numbers? Thanks...
Re: CTR/B20 swap.... (Vanilla4215)
better get some better pistons
Re: CTR/B20 swap.... (Plan B)
From what i understand it isnt very expensive - actually rather cheap. B20 longblock goes for about $600-$800, $1000 for the b16b head, another $1000 for tranny, $1000 for other misc. stuff. As for difficult, its almost identical to an LS/VTEC swap, which is not very difficult. A b20b block with a 1G B16a, stock B20 pistons is getting 173whp and 130 lb/ft. of torque...thats damn good.
http://crx.honda-perf.org/articles/crvtec/crvtec.html
[Modified by Rydaddy, 6:57 AM 7/16/2002]
b20's are hard to do right. And very expensive. I personally do not suggest it.
I would recommend ditching the stock slugs...
Mine baselined 189hp & 144lb/ft.
[Modified by Coyote2000cc, 6:59 AM 7/16/2002]
Re: CTR/B20 swap.... (Coyote2000cc)
A note of advice, compared to the other B series the 20 has the thinnest cylinder walls, if you go oversize go 84.5, I went to 85mm and recently thought I cracked a cylinder wall, turned out to be a blown headgasket but I was really sweating it there for awhile
Re: CTR/B20 swap.... (ridge racer 2)
nice dyno numbers! im not to familiar with b20s but i am familiar with ls/vtec.... my friend is dropping his second one in tomorrow..... i have another friend that just bought a b20z w/gsr head..... for my project i just got my b16a head ported and polished with 3 angle valve job for my ls/vtec... and im waiting to get my ctr pistons......i will post the pics but i can figure out how to up load it!(flame away) i think ls/vtec is the best bang for your buck NA motor but b20 has crazy torque....... for more info you can check out http://www.clubsi.com NA forum
Since when is 3800 plus install cheap?
[Modified by Rydaddy, 3:50 PM 7/16/2002]
Future Texas Boy
Re: CTR/B20 swap.... (b20bastard)
are we calling your motor "bone stock" again? lol
Don`t expect the same numbers by simply slapping a vtec head on.
Ryan
[Modified by vtecvoodoo, 3:53 PM 7/16/2002]
Ryan
Re: CTR/B20 swap.... (SiBirdie)
[Modified by Rydaddy, 1:38 AM 7/17/2002]
Re: CTR/B20 swap.... (Rydaddy)
how much are you getting the b16b/b18c5 head for? if its a good deal go for it, but if it cost 1500 and up you should buy a b16a head and get it ported........thats my opion..... good luck
itr/ctr rods will not work.... the stroke is diff..... if it works in the b20, whats the use of getting b20?
[Modified by DOHCtorTHRUST, 9:25 AM 7/17/2002]
Re: CTR/B20 swap.... (Halo)
Remember the B20 uses a totally different cylinder liner design than any of the other B-series. Its also siamesed unlike any of the other B-series. When I was trading my bare B18c for my B20 and compared them side-by-side, the cylinder walls looked hella thicker on the B20. And i got several comments to the fact from several other Honda hotroders while tearing it down...
Re: CTR/B20 swap.... (Rudy)
If you wanted torque you sure as hell picked the wrong car to get it out of.
www. HONDA-tech.com
[Modified by Rydaddy, 4:59 AM 7/18/2002]
youll only get the torque if you use the B20 rods...CTR pistons will give you the most compression gains, B16 pistons run a close 2nd...get the Z10 girdle also...for an extra $300, itll save you a lot of headaches
Re: CTR/B20 swap.... (rainmanEK)
b20vtec is the best of both worlds , YOu get the most torque ever on a B series.. and you have vtec which also make top end power with some head work.
I dont know but I love my b20vtec because I dont need to downshift to pass anyone in the hwy just give it a little gas =P
Re: CTR/B20 swap.... (CC94B18)
B20/VTEC
check out this one, has ITB's too:
