cruise control not with GSR cluster?
i was doing some searching around on GSR clusters in the 96-00 civic and i saw something about if the clusters are switched.. you aren't able to get cruise control to function on the civic... can someone tell if this is true or why this is.. or is there a way to get it to work?
Re: cruise control not with GSR cluster? (pureaznxex)
Cruise will work in an EK, i made it work in mine. You will have to take the red and blue wire out of your green plug (cruise control) and wire that into the B plug, the pins are different on the two different plugs. Then you should be set. Let me know if you have anymore questions.
spooncivic1
04-05-2006 07:53 PM
HmgLauj69
06-08-2005 10:48 AM
CHONCH
06-27-2004 08:12 PM
