Crankshaft Pulley
Crankshaft Pulley
How do you remove the crankshaft pulley from a D15B7 motor? (single cam civic DX motor) w/o power tools, BY HAND, there are holes in the pulley i guess you can stick some object in to keep it from turning and then removing the bolt by socket wrench, lefty lucy righty tighty??? i have tried different ways, I need help!
Re: Crankshaft Pulley (EG2 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR »</TD></TR><TR><TD CLASS="quote">maybe try a crank pulley wrench.
No other way if u dont have 1??? any other tools you can use??
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR »</TD></TR><TR><TD CLASS="quote">Remove the dust cover from the tranny and wedge a screwdriver into the flywheel. It's ghetto as hell, but it's your engine.</TD></TR></TABLE>
not ghetto at all. And don't use a screwdriver, use a close ended wrench between the flywheel teeth and tranny housing
Re: Crankshaft Pulley (Emerika)
don't they make a flyweel tool too, that has teeth on it? It's supposed to bolt to the housing and lock the flywheel. I have never been able to find one though.
if it has a manual tranny, put the car in gear, and have someone step on the brakes. this will keep the engine from moving. then brake the bolt loose with a 3'+ breaker bar. i used a 24" lug wrench
Re: Crankshaft Pulley (JspecEG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JspecEG2 »</TD></TR><TR><TD CLASS="quote">Alright thanks homeboys, i need 2 change the waterpump on my civic and i know it will make everything easier to take the pulley off and then remove the gay *** lower plastic cover </TD></TR></TABLE>
don't forget to Hondabond™
djnikko
19
04-24-2005 07:43 PM
94vtecmn
04-21-2003 12:08 PM
