Is this crank re-useable
Specs
Honda integra db-6 jdm 1997 sohc ZC
P2a-4 head and pistons
Last year the engine was struggling to start so we got the bearings replaced and the engine rebuilt
And this year the owner got the engine changed cause it overheated and damage the block so i asked for the crank,pistons and rods so i can get a block and install them into..So the engine was i got the crank from but i notice a rough surface on one journal slightly
Re: Is this crank re-useable
measure the journals to see if its still within spec of the engine if not get it ground if possible and use oversized bearing. if its still within spec get it polished up
Head to a machine shop, they will have the answers you are in need of.
The crank that came out of my freinds old motor looked worse, but a machine shop said it was no problem and little while later it was as good as new.
take it into a machine shop and have them micc it to be sure its within honda factory limits it looks like it will polish out nice imo
i saw a code bbbab on the crank end side of the block i know its the main bearing code
Kafelatte
12-05-2006 06:30 PM
