Crank pully
Crank pully
So i went to local junk yard friday and they got in a 98 gsr motor of course pulled out but nothing on inside and trnk was locked. so i went inside and pulled seats down and i cam across a crank pully that came off that motor i bought for 10bucks lol. Now my question is Will it work on my b16a2? Here is a pic!
well it looked simliar design to the unorthodox crank pully and i was wonderen would it even increase a bit of hp or tq ? if not then ill just stick wit factory
You aren't going to see much difference from changing pulleys. Biggest problem with aftermarket pulleys, is that they aren't spun balance. Honda's engines are internally balanced, and you stick something that is out of balance on you have just created a mess, and your main bearings will hate you. So unless you searching for every last hp out of your engine, then I would stick to stock or upgrade to something oem like a CTR pulley. Then of course your will have to sacrifice your acessories!
ilovemydc5
02-02-2007 01:24 AM
