Crank Pulley Removal
Hey guys I am in the process of disassembling my girl's 94' CX. I have the head off and need to now get the Crank Pulley off so I can remove the timing belt and then replace the water pump. I do not have an impact wrench in my garage so that suggestion will not help. I assume that somebody must make the tool that will fit in the many holes around the outside of the pully and hold it while I use a rachet on the bolt holding it on there. I tryed searching on SnapOn.com and MacTools.com but dont see what I am looking for on there. Does anyone know where to get one at? Do I have to go to honda, or has anyone ever had one of these tools made? Thanks
Re: Crank Pulley Removal (Albino Dragon)
I've seen such a tool made by Moroso.
I've always had good luck with pinning down the flywheel and using a breaker bar with a 4' pipe extention.
SLPR..........
[Modified by SLPR, 2:49 PM 2/18/2002]
SLPR..........
Re: Crank Pulley Removal (SLPR)
I dont have the tranny off, so I dont think that there is a way to pin down the flywheel, is there? Do you know where I could locate this moroso piece? I looked at there site and cant get anyway, maybe they are under construction or something?
Re: Crank Pulley Removal (DragII)
remove the starter, and wedge a screw driver in the flywheel....unless you have airtools
no it wont...I've done it several times...do a search, and you will find that is the recommended way...you just wedge it into one of the teeth.
Thanks for the info, I will try this method and see if I can get it to work. I did try searching and didnt come up with anything that looked like it would work, without the tool.
thanks guys
thanks guys
Re: Crank Pulley Removal (DragonCTR69)
The tool your looking for is the Moroso 61805 and can be bought from Summit Racing for about $70.
4ft breaker bar and this tool got it done for me.
mjsotelo91
55
09-21-2013 02:19 AM
coreyhayman
57
10-05-2006 11:44 PM
djnikko
19
04-24-2005 07:43 PM
