Crank pulley help
Old 04-24-2011, 01:47 PM
ibemike's Avatar
Default Crank pulley help
I have a 1993 Civic Si with Sohc ZC vtech motor and the crank pulley (somewhere on the highway) fell off, along with the bolt and woodruff key. I've searched around and got different bits of information. Can i use the parts off the D16a6 motor from the 88-91 civic SI? Also, here is the list of parts that I'm going to purchase: Crank pulley, Woodruff key, bolt+washer. Can someone let me know if I'm missing anything else? Here is a photo for you guys have a better look. Thanks in advance.
I called and asked Honda dealership if the parts are compatible with one another and they have no clue.
Old 04-24-2011, 02:06 PM
madjap's Avatar
Default Re: Crank pulley help
I don't know which pulley you can interchange with....but I can say that you might need a new crank....
That keyway looks wasted! I don't think a new woodruff key is going to keep the pulley in place.
Not trying to bring you down man....it just really looks bad.
Old 04-24-2011, 02:07 PM
apexi_rsx's Avatar
i dont think just getting a key and crank pulley with bolt and woodruff key will fix your problem. it looks pretty rounded off like u would need a new crank. you can try it. i believe i have a spare z6 crank pulley if ur looking for one. its the same as a zc
Old 04-24-2011, 02:53 PM
Former User's Avatar
Replace the crankshaft or the block.
Old 04-24-2011, 03:25 PM
ibemike's Avatar
Do you think I can buy the parts from Honda and if it doesn't work I can return the items for a refund? I am going to try the pulley off the d16a6, which should fit from searching the net.
@RonJ - Do you recommend replacing the whole engine instead of fixing the expensive crankshaft?
Thanks for all of your help.
Old 04-24-2011, 03:30 PM
If you have the experience and skill, replace the crankshaft.
Old 04-24-2011, 04:28 PM
ibemike's Avatar
Do you happen know what crankshaft I would need for my vehicle?
Old 04-24-2011, 04:32 PM
Master Detailer
98civdx's Avatar
Get another Z6 crank.
If your not experienced in doing that sort of thing (basically a full re-build) then try and find another short/long block and swap it out.
On top of the crank being damaged, there's no telling what lies inside.
Old 04-24-2011, 06:11 PM
ibemike's Avatar
Half the key is still lodged in the key whole. Any way to take that out?
Old 04-24-2011, 06:16 PM
hotdoggies's Avatar
Maybe a pick...maybe. Im currently dealing with the same situation. Unfortunatly looks like a new motor since im nt gna replace the crank on a high mileage engine
Old 04-24-2011, 07:48 PM
Seagull Management
94EG8's Avatar
You want parts for a D16Z6. That keyway is pretty messed up. You can try welding it with a torch or bronzing it and cutting out a new keyway. Don't try to weld it with an electric welder as it may arc through the main bearings. Other than that you'll have to at the very least replace the crank.
Old 04-25-2011, 07:02 PM
Josueneta's Avatar
Well u need a new pulley and the key the bolt with the balencer "washer" and both timing belt guide same this happen to me last month with my ls del sol
Old 04-25-2011, 10:47 PM
ibemike's Avatar
Thanks for the help fellas. I just need my car running temporarily, since I'm leaving to the military anyways. Going to go to the Marketplace for some parts.
Old 04-25-2011, 10:52 PM
evilclown312's Avatar
Its not shocking that the pulley fell off after seeing that key hole. A new one is going to do the same thing... Im sure you can pick a block up for next to nothing.
Old 04-26-2011, 04:28 AM
apexi_rsx's Avatar
yeah im sure u could find a non vtec bottom end for 200-300 bux and have the same thing putting that head on. same as a mini me swap
chrisdavis6
05-11-2012 05:29 PM
:::SIRll_EJ1:::
09-25-2008 10:55 AM
DJNauTicz
05-02-2007 11:31 AM
HonCiv
12
11-15-2002 10:01 AM
Quick Reply: Crank pulley help
