crank pulley chatter?
i am having a chatter noise that sounds low like the serpintine crank pulley... when i rev the motor the pulley moves away from the motor about an 1/16 of an inch...
i can also move the pulley with a flat head screw driver about an 1/8th of an inch using the a/c pulley as leverage... is it supposed to move? the chattering sounded like a water pump, and i stumbled across the crank pulley movement while looking for the source of the noise. i feel like it is the pulley moving separate from the crank.. but i am not sure... but the bottom gear for the timing belt is not moving out with it Modified by geldingmakr at 11:18 AM 8/3/2004 |
Re: crank pulley chatter? (geldingmakr)
ok i removed the crank bolt and the pulley...
the crank key was gone... the pulley was ground out to the point you could hardly tell there was a key way there... and the crank's key-way was larger on the end and got smaller towards the engine... like a trapezoid.. not a rectangle... http://honda-acura.net/forums/attach...chmentid=29832 |
Yeah this has happened to me..
I thought my water pump was going out and it's the pulley that my AC belt goes on.. I had to tighten it up but yet it still keeps doing it sometimes.. goodluck! |
same thing happened to me i recommend that u do not keep driving with the crank pulley like that i kept driving and eventually the key chewed up the crank and the pulley
