Crank Fluctuation sensor.. need help
i have a 97 ek9 and just but in a b20 vtech swap.. this CEL code pops up and dont know what it is.... any help???
Re: Crank Fluctuation sensor.. need help (nengx07)
what year is your motor ?? It's a sensor that bolts to the oil pump behind the crank pulley.....it gets it reading from a toothed wheel that sits behind the crank pully and tell's the ecu when to fire the spark
my b20 is a 97-98 block.. b20b.. how does tyhe plug look like or describe it.... ill try to locate it n see if its plug in right tho
TurboGoKart
12
04-06-2017 03:34 PM
PushinRedline
11-05-2007 09:06 AM
00, 97, b20, b20b, civic, crank, crankshaft, fluctuation, flukuation, fluxation, gsr, honda, located, motor, sensor
