just installed a mech. oil pressure gauge. ? about readings.
i noticed at ideal warmed up it reads about 20 psi and in D it reads about 17 psi. is this normal or do i need to be concerned? i have 187xxx on the motor. any help would be nice thanks James
Re: just installed a mech. oil pressure gauge. ? about readings.
Where did you install the gauge, and what motor is it, at what RPM are you getting 20 psi?
My B18C likes to be around 60 psi at 3000 rpm
d16z6 and 8 900 rpm at ideal. its installed where the oil pressure switch was and put a brass t block in with the stock oil pressure switch, oil gauge.
mister2racer
06-03-2004 03:46 PM
