Crank Angle Sensor on the D16y8's
Old 02-27-2004, 01:25 PM
Vtec92Civic's Avatar
Default Crank Angle Sensor on the D16y8's
My friends car was stolen, and they fucked his motor up so I put my motor up for him which is a 92 D16z6 motor . . . he just needed something to get his car running becuase he drives his car for work. I noticed that the y8 motors have a crank angle sensor and the z6 blocks don't. Will his car run without having that connected?
Is there anyway around this and if so what would it be? The motor is going into a 2000 Civic EX Coupe. He is aware that the motor is from an older car, but since we live in Hawaii and there isn't really any other source or transportation besides a car that is why we are swapping the motor.
PM me or IM me on AIM with any and all info . . . . thanks in advance
Will the car start or run normally without the crank angle sensor connected?
Old 02-27-2004, 01:27 PM
ARIZONA's Avatar
Default Re: Crank Angle Sensor on the D16y8's (Vtec92Civic)
OBD1 will not require a Knock...
OBDII will look for it, and you will get CEL without it.
Old 02-27-2004, 01:36 PM
Default Re: Crank Angle Sensor on the D16y8's (ARIZONA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARIZONA &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 will not require a Knock...
OBDII will look for it, and you will get CEL without it.</TD></TR></TABLE>
yeah we told him that he will get a CEL light he doesn't care, he just needs his car, but someone told me that the car will prob. not start if it's missing the crank position sensor . . . is that true or false?
Old 02-26-2006, 04:14 PM
Technical Hero
HondaPartsHero's Avatar
I have a friend in the same situation identically to this. I am going over there to take off the crank pulleys to compare. What on the Y8 does the crank angle sensor read off of?
Old 02-26-2006, 04:25 PM
Technical Hero
Default Re: Crank Angle Sensor on the D16y8's (HondaPartsHero)
actually now that I look at it are the Y8 and Z6 oil pumps interchangeable? If someone knows this chime in anytime, thanks
Thategguy94
02-07-2015 01:15 PM
eg6civic1538
04-15-2008 04:46 AM
fq200turbo
08-28-2006 04:06 PM
Staples
03-19-2005 08:34 PM
SuzukaBlueAP2
10-28-2003 06:23 PM
Quick Reply: Crank Angle Sensor on the D16y8's
